Hello all. For 2 weeks now my bottom right button won't work and I use it all the time to pause once Im done swimming and then register it. At this point I can't even pause on the touch screen so I have to completely turn it off and then my swim will br registered on the app but not on the watch. Ive tried restarting watch with back and bottom button 3x in a row and still nothing. TIA
Hi @BekaA That sounds really annoying. I think you will need to try a factory reset. Settings app app and scroll down to About or button method below. If the button still wont work, please come back here
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
Both my top and bottom buttons no longer work. Tried factory reset and now I'm stuck on the "press teh top button for notifications" screen and no way to do anything. Back to Garmin I go or Apple, at least their hardware works.
