You should not have to restore factory settings to fix it. It take time and date from your phone or other sync device at each sync, so your next sync should fix the time.
I realize this doesn't address why time got off in the first place.
@eefke78 It's great to see you in our Fitbit Community! I'm sorry for the late response. However, I would like to follow up and would like to know if the issue persists or if your Versa displayed the correct time after following @JohnnyRow's advice.
If you found his post helpful, please mark it as a solution so other users that experience the same issue can check it out.
In case the issue persists, please restart your Versa as described in this help article and sync your tracker.
Looking forward to your response! ![]()
Best AnswerSorry for the late reply as well.
It is behaving nicely now... did not change anything. Hope it won't happen again.
I will make sure it syncs regularly.
Thanks!
Hi @eefke78, just be sure before you sync it that the Time Zone on your account is correct, as this is what the Versa syncs to.
one cruise ship at a time!
03-27-2019
10:01
04:19
03-27-2019
10:01
04:19
@eefke78 I'm so glad to hear that your Versa is working properly now. Thank you for posting the update here. Thank you for posting the update here.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Thank you so much for pointing out this important information my friend @DramaQueenDiva!
See you guys around! ![]()
