08-24-2020 16:37
08-24-2020 16:37
Has anyone had a bright white line on the side of their Versa 2? Just happened this weekend- will light up an entire dark room! I have turned the watch on/off several times, charged it, changed watch faces, nothing worked!
08-24-2020 16:38
08-24-2020 16:38
08-28-2020 11:50
08-28-2020 11:50
I can’t find the reply or fix for this? My Versa has just done this too
Best Answer08-28-2020 15:30
08-28-2020 15:30
Fitbit is replacing it under warranty.
Best Answer09-02-2020 08:30
09-02-2020 08:30
Hi Mine is doing the exact same thing. I already replaced my Versa under warranty for another issue. I am now out of warranty (Although this device is less than a year old so technically should be in warranty)
