@Rick1138 you can choose Max setting. This will by default override auto brightness and keep the screen brightness at max. Just pull down the status bar on your versa 2, and tap to access quick settings and tap on the little sun icon to select Max.
Best Answer@Rick1138 oh you mean you would like the display to be always ON. Please open Settings app on your Versa and scroll down to Always-ON Display. Tap in and switch to ON. Please note that this will consume more battery.
Best AnswerHi, go to settings and press it. Press the Brightness of your display untill it says either normal, maximal or dimmed and you have disabled the automatic brightness setting. Regards kuzibri
Best AnswerDeleted, slight misunderstanding. Regards kuzibri
Best AnswerDid that and after 60 seconds (the max delay you can set) the display goes back to the always on clock display and that still auto dimms no mater when the brighness is set to
Best AnswerHi, which Clock Face are you using, a Third Party One or one developed by Fitbit itself? Regards kuzibri
Best Answer@Rick1138 you need to enable always on display. Please open Settings app on your Versa and scroll down to Always-ON Display. Tap and switch it to ON.
