04-19-2019 09:31
04-19-2019 09:31
I’ve just set up my versa and am able to get messages and calls - but no calendar notifications. I have ticked the box to enable calendar notifications, switched everything off and on as suggested but still nothing. Help!
04-19-2019 10:46
04-19-2019 10:46
You're very welcome!
Best Answer04-19-2019 09:35
04-19-2019 09:35
Hi, when you go to the calendar notifications and press it, do you see multiple choices there? If yes, choose the one you're using and restart your Versa.
Best Answer04-19-2019 10:32
04-19-2019 10:32
Best Answer04-19-2019 10:46
04-19-2019 10:46
Best Answer07-22-2019 08:07
07-22-2019 08:07
Hi, where do you find calendar notifications please?
Best Answer07-22-2019 09:56
07-22-2019 09:56
If our go on your app, select your device and there is an option for notifications. Calendar notifications has a check box you can tick..
