10-15-2020
17:57
20:52
10-15-2020
17:57
20:52
Hi guys,
I want to remove the wallet pin from my versa 3 but only seem to be able to change it which is pretty annoying, any ideas how to remove it completely??
Thanks
10-15-2020 18:49
10-15-2020 18:49
Do you have any credit cards on it? If so, I think you have to have a PIN. Imagine the outcry if a tracker got left behind at a bar or McDonalds and somebody started charging to that card with no PIN protecting it.
Best Answer10-16-2020 07:30 - edited 04-23-2024 05:31
Hi there @Gemini1974, welcome to the Community Forums. I'm sorry to hear that your Versa 3 has been locked, I understand where your concern is coming from. I'll be glad to help you.
I'm agree with @Itsameee, we know is safer to have a pin code for users who use Fitbit Pay.
That being said, keep in mind that if you set up Fitbit Pay, the device lock is turned on automatically and you’re prompted to set a code. For more information on how to use Fitbit Pay, see What should I know about Fitbit Pay?
You must enter your PIN code at least once a day. Your Fitbit device prompts you to enter your PIN code based on your device lock setting:
Note that your card issuer may require you to re-enter your PIN code to authorize a payment. To change the device lock setting:
For more detailed information, see: How do I use the device lock on my Fitbit device?
Best Answer10-16-2020 17:11
10-16-2020 17:11
10-17-2020 05:23 - edited 04-23-2024 05:30
Hi there @Itsameee, thanks for getting back and for the details shared.
I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. They will be able to work with and help you to remove the PIN code on your Versa 3. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
10-17-2020 17:11
10-17-2020 17:11
Hi- i have the same issue- I don't have a card. I may have once yet think it's removed. I don't want to have enter a pin multiple times a day when there's no need for a pin code. Thanks
Best Answer10-19-2020 07:04 - edited 04-23-2024 05:29
Hi there @JayItsMe, welcome on board. I'm sorry to hear you're also having the same issue with your Versa 2, I understand how you must be feeling about having to enter the pin multiple times a day when there's no need.
I've created a Support Case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums.
Best Answer10-19-2020 10:23
10-19-2020 10:23
Best Answer02-04-2022 11:36
02-04-2022 11:36
Have you had a reply to how to disable the pin code on Versa 3?
Best Answer02-05-2022 13:53
02-05-2022 13:53
I've checked the fitbit app and the settings on the Versa 3 and find no option for removing this pin.
Two options I can think of.
08-28-2022 12:17
08-28-2022 12:17
I have the same issue why is there no option to remove the pin
Best Answer09-04-2022 08:11
09-04-2022 08:11
That would be a question for fitbit.
Not sure why anyone would enable the pin unless they use Fitbit Pay, then I enable the pin only for fitbit pay.
