06-03-2022
00:58
18:00
06-03-2022
00:58
18:00
How do I get the sp02 app on my versa 3, I have been able to place other apps no dramas but can not get this one to come over to my watch. Do I need premium for this to work?
06-03-2022 02:57
06-03-2022 02:57
Hello @Mat- and welcome to the Community. The SpO2 Tracker runs in the background and doesn't appear as a separate icon on the device. Your SpO2 is available in your Today stats on your Versa 3. If I remember correctly, the SpO2 will be in the Today stats when the app is installed, meaning you don't need to use the EDIT option to add it.
I also want to point out that the app description is incorrect. It says you need to use an SpO2 clock face. You don't.
Laurie | Maryland
06-03-2022 02:57
06-03-2022 02:57
Laurie | Maryland
06-03-2022 05:13
06-03-2022 05:13
Hi there, @Mat-. Welcome to the Community Forums. Thanks for the details provided in your post. @LZeeW Thanks for your input!
Did you just set up your Versa 3? Less than 3 days ago? If this is the case, Since you've recently set up your Versa 3, I recommend you to check back in a few days to see if you can go ahead and download the SpO2 clock face. For more information, see How do I track blood oxygen saturation (SpO2) with my Fitbit device?
See your SpO2 trends in the Health Metrics tile in the Fitbit app on your phone. The Health Metrics tile is available with Fitbit Charge 4, Fitbit Charge 5, Fitbit Luxe, Fitbit Sense, Fitbit Versa 2, and Fitbit Versa 3. To see historical data, upgrade to Fitbit Premium.
Hope this helps.
06-06-2022 13:52
06-06-2022 13:52
Thanks for the advice 👍
06-08-2022 13:30
06-08-2022 13:30
Cheers thanks for the advice 👍
