12-27-2020
09:54
21:46
RicardoFitbit
12-27-2020
09:54
21:46
RicardoFitbit
Stopped wearing versa 2 for a few months. Went to reconnect but having loads of issues.
Turned phone on and off
Turned Bluetooth on and off
Reset fitbit
Reset phone
Unistalled and reinstalled app
Cleared Bluetooth cache
Factory reset phone
I can get as far as inputting the 4 digit code displayed on the fitbit in the setup then it just says "connecting" for ages or it asks me to try setting up again.
Any ideas as I feel like I have done everything possible and it still. Won't connect
Could this be a phone/Bluetooth issue? If anyone has advice on this that would be great too. Thanks
12-27-2020
21:46
13:07
12-27-2020
21:46
13:07
Hi @Alexh164, welcome to the Community Forums.
First, I'd like to appreciate your effort and patience troubleshooting this situation prior to posting. To better assist you with this, can you please let me know which phone are you using with your Versa 2? If you haven't already done so, I recommend you to check all the information that's specified on: How do I set up my Fitbit device? to check if all the requirements are correctly configured to setup your device. Then, you can move forward and try the troubleshooting steps that are specified on: Why can't I set up my Fitbit device? and let me know how it goes.
Let me know if further assistance is needed and if you have any additional questions.
