Card not available on Versa 2
I have entered my card in the app on my iPhone and verified it with my bank, but the watch still says «No cards have been added in wallet».
I have tried factory reset of the watch and added the card again. Still the same message.
3 REPLIES 3
@Tvittertaus Welcome to the Community. Sorry for the delayed reply.
Thanks for mentioning that you've checked your card with your bank but it's still saying no card available. I appreciate the factory reset done.
I would like you to make sure you did this procedure to add cards to your Ionic. Please check your bank is in this list. If you're still experiencing the same, please attach an image to your next reply.
I'll be around if you have any additional questions.
I have solved the problem. The soloution was to set the card as «default for this Versa2» which was not an obvious solution since it was the only card added to the wallet.
Thanks for the reply.
@Tvittertaus Thanks for getting back. I'm glad to hear that you got it resolved by setting the card as default to your Versa 2.
