11-10-2019 02:10
11-10-2019 02:10
How can I change the clock display on my Fitbit Versa 2. The one that stays on the screen, it is the one before I press the side button to get clock and stats?
11-10-2019 02:33
11-10-2019 02:33
It's not something I've done myself but I found this in the Versa 2 manual:
https://staticcs.fitbit.com/content/assets/help/manuals/manual_versa_2_en_US.pdf
Best Answer11-10-2019 02:33
11-10-2019 02:33
Best Answer11-10-2019 02:47
11-10-2019 02:47
Best Answer01-11-2020 12:40
01-11-2020 12:40
I've gone to the settings and set my clock to digital, but it's not changing it. When I go back to the clock, it is still in analog mode. Any help would be appreciated.
09-04-2020 16:14
09-04-2020 16:14
Same problem here...
If you use "always on display" mode, the "clock faces" only work when unlocked.
Please correct this
12-10-2020 17:00
12-10-2020 17:00
It is very odd that "Always On" doesn't simply leave your selected clock face on all of the time. It also appears that the Always On display does not change unless you actually hit the side button. I would think it would switch to your selected clock face when you move the watch towards your eyes. Apparently not. Thankfully the default analog watch face that Always On uses isn't too terrible.
05-20-2021 09:04
05-20-2021 09:04
I called fit bit. They said when you choose your clock face you need to choose from the always on clock faces. Makes sense I guess. I just wish the one I chose was an always on face...
