Change clock face
How. To change clock face
9 REPLIES 9
Hi @ppero , yo can change the clock face by pressing in the dashboard of your Fitbit app the watch icon on the left side in the Today bar. You see the page with tiles Clock and Apps, etc. Press Clocks and you'll see My Clock (the current one you're using) and All clocks. Press the last one and search for the CF you want to install, select it and install it. Regards kuzibri
BTW, just a tip: search for a CF called Minimal Style. It's indeed Minimal, but gives you all the stats you want, is highly customazible with only a size of 8.6 kB, so very battery friendly. I use this CF already for a long time and my Bersa 2 lasts on one charge 7 full days.
Got it....thank you!!!!!
Sent from Phyllis's IPad...
You're most welcome, regards kuzibri
@SunsetRunner  I tried searching for the CF "Minimal Style", but there is no CF specifically called "Minimal Style".  Is it not available for Versa Lite?
Hi @SunsetRunner , if you cannot find it, it's not available for the Lite due to the discrepancy in display size or due to the fact that the developes only updated it to the Versa 2 and not the Lite. Regards kuzibri
@SunsetRunner  That's too bad.  I was hoping to use a CF that didn't use much battery and was highly customizable.
Hi @SunsetRunner , contacted the developer and asked him whether he is planning to make a Lite version. whenever I get an answer to this I will let you know, regards kuzibri
I have a Versa 2.
Then you can install, if you want, the minimal style CF, regards kuzibri
