04-25-2020 06:20
04-25-2020 06:20
I just got a versa 2, and the only shortcut it’s letting me set got my left button is either Alexa or Fitbit Pay... I want to have exercise as my left button shortcut and not either of the other two. Is there a way of doing that??
04-25-2020 06:33
04-25-2020 06:33
Hi @Allanah5678 and welcome to the forums! Here are the instructions to change the short cut for the left button on the Versa 2.
From the Versa 2 clock face
That should do it. Please let us know if you have any other questions.
Best Answer04-25-2020 06:51
04-25-2020 06:51
Hi carol, thanks for your reply!
When I tap on the left button option in settings, I can’t get to the screen you mentioned? Every time I tap it I’m still only getting either Fitbit pay or Alexa... I couldn’t seem to swipe to get the option to chose the shortcut?
04-25-2020 08:27 - edited 04-25-2020 08:28
Hmmm ... @Allanah5678 ... Here are a couple other things to try:
Please let me know if that helps.
Best Answer04-27-2020 06:22
04-27-2020 06:22
Hi Carol,
I'm not sure what's happened, but I just tried it again there and it's finally worked!
Not sure what made it work in the end, but it's sorted now haha.
Thank you for your help 🙂
05-17-2020 07:29
05-17-2020 07:29
I've tried resetting several times, and OS is up to date, but still have this issue. Is there something else I should be doing?
Thank you 🙂
Best Answer05-17-2020 07:36
05-17-2020 07:36
Hi there,
I’m really sorry I can’t be of more help, I’m actually not sure what caused mine to work!
I restarted it a few times more and then tried it again a day or two later and all of a sudden it was working! But I’m actually not sure what it was that made it work in the end... as unhelpful as that may be!
I hope you get sorted 😌
Best Answer05-17-2020 07:55
05-17-2020 07:55
Thank you! That is helpful, I'll just give it a day or two & try again. Not a huge deal in the grand scheme of things, I just don't use Alexa or the pay function at all. I would have just purchased the Versa but too excited about the music feature!
Thanks again!
