04-24-2020 07:00
04-24-2020 07:00
During travels we lost the charger dock to the versa. I have now tired 3 different replacement docks and none of them has worked! This is the second time that the have purchased a fit bit and run into this problem. Where can I get a dock that works?
04-24-2020 07:22
04-24-2020 07:22
First I would make sure you buying the correct charger. Versa and Versa 2 chargers are different.
If you took that into account, where did you buy them/were they official Fitbit ones?
You should be able to buy from the Fitbit store here
https://www.fitbit.com/us/products/accessories/versa2-charging-cable
or https://www.fitbit.com/us/products/accessories/versa-charging-cable.
Or they are available on Amazon, third-party and perhaps Fitbit originals. I have never had a problem with third-party chargers but I suppose you are safer with Fitbit originals.
Best Answer04-28-2020 05:15
04-28-2020 05:15
It was the right charger. After days efforts and buying 3 different charges we discovered that we had take the writs band off in order to work on one charger. On another charger we have to "clip" it with a quick connect. IN any case that was the solution.
