04-10-2018
17:33
10:11
JuanJoFitbit
04-10-2018
17:33
10:11
JuanJoFitbit
Hi there: Just got my Versa today. Very excited. All charged and synced and updated and ready to go. I can't seem to get the clock face to show! It's stuck on tips and tricks and inspiration. I can swipe it to go to notifications and music, but not the clock. Cannot figure this out and feel pretty stupid! Thanks for any help!
Best Answer04-10-2018 18:02 - edited 04-10-2018 18:03
Hi @dglazer,
Welcome to the forums!
Try performing a restart from the instructions below. And let us know if that fixes it.
Hi @dglazer,
04-10-2018 18:14 - edited 04-10-2018 18:17
You should be able to just tap or swipe the screen and the Tips and Tricks message should go away. If that doesn't do the trick, Dave's Restart suggestion will certainly work.
Best Answer04-10-2018 19:33 - edited 04-10-2018 19:34
Thank you @WavyDavey! That worked!
Best Answer09-30-2019 07:19
09-30-2019 07:19
Thanks WavyDavey. Clock now showing the time again following restart.
10-25-2020 14:28
10-25-2020 14:28
Worked perfectly! Time is now displaying!
Best Answer01-01-2021 15:55
01-01-2021 15:55
My clock face will not display when I raise my wrist. I did a restart. Nothing change. I have to tap the screen twice to get the clock too display.
Also, when I go into settings and select “display” the options “darken”.
Best Answer01-02-2021 00:06
01-02-2021 00:06
It seems like you are in sleep mode.
From the main view swipe right and have all the 6 icons greyed except the wrist [middle bottom]
01-02-2021 07:10
01-02-2021 07:10
Spot on, thanks.
