Clock face not showing on display
ANSWERED
Hi there:  Just got my Versa today.  Very excited.  All charged and synced and updated and ready to go.  I can't seem to get the clock face to show!  It's stuck on tips and tricks and inspiration.  I can swipe it to go to notifications and music, but not the clock.  Cannot figure this out and feel pretty stupid!  Thanks for any help!
1 BEST ANSWER
Accepted Solutions
Hi @dglazer,
Welcome to the forums!
Try performing a restart from the instructions below. And let us know if that fixes it.
Restart Fitbit Tracker
Work out...eat... sleep...repeat!
Dave | California
8 REPLIES 8
Hi @dglazer,
Dave | California
You should be able to just tap or swipe the screen and the Tips and Tricks message should go away. If that doesn't do the trick, Dave's Restart suggestion will certainly work.
Thank you @WavyDavey!  That worked!
Thanks WavyDavey. Clock now showing the time again following restart.
Worked perfectly! Time is now displaying!
My clock face will not display when I raise my wrist. I did a restart. Nothing change. I have to tap the screen twice to get the clock too display.
Also, when I go into settings and select “display” the options “darken”.
It seems like you are in sleep mode.
From the main view swipe right and have all the 6 icons greyed except the wrist [middle bottom]
Spot on, thanks.
