How do you change the time on Vera Lite watch? Incorrect time is not due to time change.
You can't manually set the time but it should reset itself whenever it syncs to your phone or computer based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the timezone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
Best AnswerI thought updating would fix the problem but it did not. The app says it cannot find my device. But it says that it's synced it on Wednesday evening. Now my Bluetooth won't even recognize my versalite
