09-28-2019 05:29
09-28-2019 05:29
Hello is it possible to download the clockface with the fingerprint in the background for the versa?
i saw it passing in the advertisement of the versa 2.
09-28-2019 07:27
09-28-2019 07:27
the name of the clock face is call "waveform"
09-28-2019 05:44
09-28-2019 05:44
Hi @Ellis_ - I did a search for “fingerprint” in the clock faces for my Versa 2 but it did not show anything. Was this an analog or digital clock face? The clock face may be available for the other two versa models. I cannot check that. Perhaps others here can?
Best Answer09-28-2019 06:46
09-28-2019 06:46
this is the clockface I’m looking for...
Best Answer09-28-2019 07:18 - edited 09-28-2019 07:19
@Ellis_ - Thanks for the photo. The first two are definitely available. I’ve seen many versions of the analog face on the far right. So you should be able to find one you like. It all depends on which features you want to see when you flick your wrist. I like the one below, called Classic because it shows steps and day/date.
09-28-2019 07:27
09-28-2019 07:27
09-28-2019 07:56 - edited 09-28-2019 07:57
@RagnoX is correct and as far as I know is only available for Versa 2. So to answer your initial question, no it's not available for download on the Versa.
09-28-2019 09:06
09-28-2019 09:06
Thans for the answer. Too bad its nog available for the versa.
Best Answer09-28-2019 09:07
09-28-2019 09:07
I want something simpel with date, heartrate and steps
Best Answer09-28-2019 09:54 - edited 09-28-2019 09:55
I use "Stats" by Fitbit. It has time, day of week and date (only the day of month), seconds and also Steps, cals and heart rate. Simple and has all the stats I really need, actually it's quite similar to waveform.
