03-13-2021 00:33
03-13-2021 00:33
Hi,
I'm looking to change my phone as I have just got the Versa 2 and have issues with it with my current phone.
After looking the compatible phones list it all seems to be older phone's.
Anyone have a recommendation Inna phone to get that is compatible with the Versa 2 ? Preferably android ? I was looking at the Samsung S21 does this one work ok with it ?
Thanks for any advice and help
03-13-2021 01:30
03-13-2021 01:30
You can check which phone is on the compatible phone list. Supposedly the phone you mention will work, but as its new there may be differences or issues.
If you are changing phones merely because of syncing issues its probably simpler to correct the setup issues causing the problem.
03-13-2021 02:34
03-13-2021 02:34
