03-11-2019
17:03
10:17
JuanJoFitbit
03-11-2019
17:03
10:17
JuanJoFitbit
Hi,
This evening my Fitbit Versa (bought approx 7 months ago) began acting strangely (navigating to the Bike workout on its own, turning itself back on straight after pressing the left button to turn off the screen). After a few minutes of this, it began to show only the blue Fitbit logo, seemingly restarting over and over without ever loading the clock face.
After getting home and charging it for a while, the clock face would occasionally load in between these restarts. I reset the clockface to the default thinking it might be an issue with that, but the reset loop continued. After a while it no longer even showed the Fitbit logo, just coloured bars on the screen that would change between blue, green and brown on each reset (see screenshot linked below). I tried to follow the factory reset instructions on Google but the watch is non-responsive to any attempt to manually shut down or start the device, and doesn't vibrate at all in the manner described by the factory reset process. It continues to reset itself over and over.
Turning over the Versa, I found condensation on the sensor panel (see other screenshot linked below). I was walking for a few minutes in heavy rain today but never submerged the watch. I regularly swim in pools and occasionally lakes and have never had this happen before.
Has anybody had a similar experience and does anyone have any suggestions about how to fix this problem.
Moderator edit: Labels
06-23-2020 14:49
06-23-2020 14:49
Best Answer06-23-2020 15:52
06-23-2020 15:52
I am experiencing this same issue! I wore it in the pool a few days ago, dried it completely and continued working as usual. Then 24 hours later it has stopped working entirely, everything stated in previous posts to this forum are happening to my watch. Today, I discovered the condensation in the back. I have tried everything they recommend to fix this issue.
Best Answer06-23-2020 15:58
06-23-2020 15:58
Best Answer06-24-2020 07:38
06-24-2020 07:38
Wow that's great! They only offered me 25% off since it was out of warranty 😞
Best Answer06-24-2020 07:39
06-24-2020 07:39
Thank you! At first it was turning on but it continued to glitch. Now the screen is completely fried and I would more than likely have to purchase another fitbit.
Best Answer06-30-2020 05:41
06-30-2020 05:41
I’m having the same problem. Fitbit versa got hot on my wrist and must have automatically Turned off. Thought it overheated and shut down so let it cool back down. Tried to turn it back on and nothing would happen. Just a black screen. Tried to holding all three buttons to manually reset and nothing happened. Noticed the condensation on the back sensors so put it on a bag with desiccant pouches. Now the condensation seems to be gone but it still won’t turn on. Left in charger for over thirty min and it now gets quite warm on the charger and still doesn’t turn on. Haven’t had it for a even a year. 😞
Best Answer07-07-2020 19:09
07-07-2020 19:09
hi could you let me know how to get in touch with customer support I have had my versa for a little over a year and swim in it regularly but this past wknd it shut off and I noticed the moisture! I'm really missing it and need this fixed as soon as possible! Thank you for any help!
Best Answer07-07-2020 19:30
07-07-2020 19:30
07-07-2020 20:02
07-07-2020 20:02
Dear Lanuza
I am also experiencing some condensation in the sensors as well. My versa stopped working last week And tried to charged it all night and nothing.
could you ask the Fitbit team to contact me please
Best Answer07-08-2020 05:18
07-08-2020 05:18
This just happened to me, is there a solution? My fitbit versa will not turn on at all, will not reset, and will not light up when on charger... I was in a kiddy pool with my 3 month old yesterday and it worked until about 2 am when I got up to feed him the screen was completely black and has been ever since.
Best Answer07-08-2020 07:00
07-08-2020 07:00
07-08-2020 08:33
07-08-2020 08:33
Thanks for the info! I was able to chat with an agent and they quickly resolved the problem and will be sending a new fitbit to me once I send out my current defective one! Super easy to chat with an agent with the link provided.
Best Answer07-14-2020 14:41
07-14-2020 14:41
My Fitbit Versa turned off last night so I charged it all night and it still won’t turn on. I have tried doing all the resets and everything that the support tells you to but still nothing. I can see condensation build up where the sensor lights should be lit up but I have not submerged it in water, I am a heavy sweater though. Trying to figure out what I can do.
Best Answer07-14-2020 14:46
07-14-2020 14:46
07-14-2020 16:40
07-14-2020 16:40
Best Answer07-14-2020 17:17
07-14-2020 17:17
Best Answer07-14-2020 17:26
07-14-2020 17:26
Best Answer07-17-2020 04:53
07-17-2020 04:53
Hi
I have experienced the same thing. I bought this item specifically so it could get wet. Unfortunately mine is about a year and a half old but that shouldn't matter. I have tried everything. Reset over and over with just a blank lit screen. Every once in a while I get the logo but then nothing. I also then saw moisture in the back sensors. I tried a bad of rice overnight. Got up this morning and it was displaying 0% so I thought....good sign but it didnt last. I plugged it in and it went back to before and moisture is still in it.
Best Answer07-17-2020 05:01
07-17-2020 05:01
Best Answer07-17-2020 05:03
07-17-2020 05:03
You can contact them through the website or call. Because your Fitbit is over a year old they will not replace it for you. However it will offer you 50% off if you want to get a new one
