This is part of the message I wrote to a fellow community member re connected GPS issues on Android devices. There's a potential workaround, but I cannot guarantee it will work for everyone.
Starting with Android N or O , more stringent control over processes using GPS have been introduced. The issue is with Google Play services hogging resources and draining battery. So, basically what Android does now is it kills the processes that use GPS after some time. It seems to happen only for 3rd party apps like Fitbit, Strava, MapMyHike, All Trails etc., and not for native Google apps like Maps. Android kills these processes even if they're in the foreground. Fortunately, there's a workaround. You need to make sure the app is "locked" in the background. This way Android knows it's not supposed to kill it. Here's what I do:
1. Before my hike I make sure my versa can sync without issues. No sync - no GPS.
2. Open Fitbit mobile app.
3. Tap Android home button.
4. Tap Android recent apps button to open the drawer with currently running apps.
5. In the top right corner of each app you should see a little padlock. Normally it's in unlocked position.
6. Tap on the padlock to lock the app.
Note: for Samsung devices, please see @Srikanta post here.
Note 2: please make sure Fitbit mobile app is not being optimized by Android. In battery settings under optimization, Fitbit app should be marked as not optimized.
It seems to work for me. I was able to track numerous hikes with maps and everything. Don't worry if your versa loses GPS connection at some point. It will reestablish it. Also, losing connection doesn't impact GPS tracking as it is not performed by versa but Fitbit mobile app itself. Versa just initializes the process.
Hope that helps. I will post a picture in a separate post as Fitbit takes time to approve posts with pics.
The little padlock in the top right corner. Tap it to lock the app in the foreground.
Best AnswerI don't have the padlock. just an X
I wish the phone app would keep mileage information accurately, but this is not the case. Whenever the Versa loses connection, actual mileage does not get recorded by the phone app such that at the end of the ride, when everything is connected, the mileage is incorrect. This is different than the Strava app. It never gives me incorrect mileage; it is reproducible each and every ride. The Fitbit app varies greatly even when both apps are open and running at the same time. The relationship between the app and the Versa is more complex than simply initiating and completing the ride.
Best Answer@MJNinDallas I do not have Android N to test it as I'm running O. Previously before using this workaround each time Versa would disconnect or GPS got killed I would see straight lines ony map as the route wasn't tracked between two points. Of course distance would be incorrect as well. With this workaround at least there are no gaps and everything get tracked even if versa disconnects and reconnects. How complex the relationship between versa and mobile app is I'm not sure, but all GPS tracking is done on your phone.
Best Answer@babyblueut @MJNinDallas other solution that comes to my mind is enabling partial wake lock with this app while running Fitbit app at the same time.
Best AnswerI misunderstood your prior post to mean... the app tracks mileage correctly but the Versa displays it incorrectly at the end of the ride. Indeed the app is broken, in that it loses GPS signal where other apps (non-Google) have no problem with this functionality. You were able to lock the app, but I can't. This should work even without opening the app given that Fitbit runs a service at all times even when the app is closed. I get the same results when the app is opened or closed.
Fitbit should pay Strava to help with their GPS handling code.
Best Answer@MJNinDallas no worries.
@Couliepj not on my phone. Strava gets killed as well. This is a known issue actually (Google). As I said it might be a potential workaround for some. Still worth a try, IMHO. Even if your Strava works perfectly. 😊
I don't no if this works for me . Will try tomorrow on my run. I'm using samsung android phone with oreo(8.0).
But I would like to share how to lock the App .. this is how it looks in my android device I do not have that padlock mentioned instead I have tab expanded which shows the App lock feature
I'm able to Lock the Apps.
Meanwhile please try this work around & let us know this works for others users
@Srikanta thanks for showing the locking feature on Samsung. One more thing, also please make sure Fitbit mobile app in not being optimized by Android. In battery settings under optimization, Fitbit app should be marked as not optimized.
Best AnswerI also found this. I will see how it works and if it helps today.
How to Whitelist Apps from Android Oreo’s Background Location Throttling
https://www.xda-developers.com/android-oreo-background-location-whitelist/
Best Answer@babyblueut @Srikanta@Couliepj yes, whitelist and battery optimization settings have to be taken into account as well! Thanks for posting. 😊
Best Answer@Couliepj I fully understand your feelings because honestly I voiced them myself. Nevertheless, when it works, versa is exactly the device I wanted. I hope that it will follow lifecycle or Charge HR and after some time will get all these bugs ironed out. I remember getting hysterical about charge HR... I still believe Fitbit offers the best health-fitness platform as a whole. I, myself, am a proof, but I cannot disagree with you. The experience has been stressful so far. I hope it gets resolved quickly. Hang on in there, @Couliepj.
Best AnswerThanks for that - Strava works perfectly well and I am not sure what you say applies to our situation, when logging with Fitbit, I loose 8% of the journey mileage as opposed to Strava that records perfectly. Besides, Fitbit have acknowledged there is a problem. But thank you
