07-25-2018 15:54
07-25-2018 15:54
I just bought my fitbit versa and I'm trying to set it up. When I start trying to connect it to the app, it says found tracker, and then sits there for a few minutes and then says Bluetooth issues and then stops trying to connect it. This is really getting annoying.
07-25-2018 19:12
07-25-2018 19:12
The same It is happening to me, could you fix it?
Best Answer07-25-2018 19:54
07-25-2018 19:54
not yet, I keep getting the same thing
Best Answer07-25-2018 20:04
07-25-2018 20:04
Okay so what I did was told my phone to forget the versa in the bluetooth settings. Then I went into the fitbit app and added it in the app, next thing I know I feel it vibrate and I see the pairing numbers on the face. It finally connected.
