This is the message I get when I try to get my fit bit to work again. "Data not cleared, sync and try again. I have tried to sync several times and get the same result. My battery is at 87%. Is there anything I can do to get it to work again. Or is it just done after 3 months of use.
Best AnswerHi @Docook Try a Factory Reset. If that doesnt lear it younwill need to contact Customer Support
BUTTON FACTORY RESET FOR VERSA 2 AND VERSA LITE
Hold the back button for about 8 seconds.
When the Fitbit logo disappears: Release the button briefly (for less than 2 seconds).
Hold the button again until you feel a second, longer vibration, which indicates the factory reset.
Helen | Western Australia
Best AnswerThank you for the advice however it didn't work. I have tried everything suggested on support site with no results.
Best AnswerYou will need to contact Customer Support (link in my post above)
