10-26-2021
09:36
11:42
BraulioFitbit
10-26-2021
09:36
11:42
BraulioFitbit
I have the Fitbit versa. I have a red X in a circle saying data not cleared. I cant get rid if this. Please can you help me to fix it. I have an android device and the the watch isnt linked to any account so I am unable to pair it with my android device either. Kindly Help.
10-26-2021 11:42
10-26-2021 11:42
Welcome, @Manozya. It's great to see you around.
Thanks for the details in your post. The "data not cleared" message will appear if a factory reset was performed so you need to setup your watch again. If you're having trouble with the setup process, please try the troubleshooting steps from this help article: Why can't I set up my Fitbit device?
Hope this helps.
Best Answer10-26-2021 21:12
10-26-2021 21:12
Hey there,
I tried to set it up again but my phone is unable to locate the versa regardless of it being on. While my phone is supposed to search for the versa is the versa still supposed to show the "Data not cleared" or is there supposed to be a fitbit logo or something? Unable to solve this issue kindly help.
10-27-2021
11:38
16:35
10-27-2021
11:38
16:35
Hi, @Manozya. Thanks for the update.
Regarding your inquiry, your Versa will display the "data not cleared" message until your phone finds it and shows the 4 digits pairing code. Please check if your watch is paired to your phone's Bluetooth by going to your phone's Settings. If your watch is paired to your Bluetooth, please unpair it and try the setup one more time.
Catch you later.
Best Answer10-27-2021 20:50
10-27-2021 20:50
Hey there @BraulioFitbit ,
I tried to do as you asked me too and have found no luck. My versa isn't able to be found and i can't see the 4 digit pairing code regardless of trying on different devices. Kindly Help.
07:02
16:39
10-28-2021
07:02
16:39
Hello, @Manozya.
I appreciate the troubleshooting steps that you tried. Since your Versa is still having trouble to pair with your phone, my advice is to contact our Support team by chat or calling them. Please explain them what you've tried so far so they can look for a solution.
See you around.
Best Answer10-28-2021 16:19
10-28-2021 16:19
I went to Fitbit Support Chat. This is what they told me to do.
Make sure phone software up to date
Make sure Fitbit been left to charge for approximately 2 hours so has a decent charge ( mine was at like50%)
Make sure Bluetooth on on phone
make sure Fitbit app up to date- check on App store
Make sure have good WIFi connection
Go to Fitbit app on phone
in top left corner click account
select +Set Up a Device
if prompted select Replace
keep Fitbit near phone
You will be resetting up Versa
You will get grey Fitbit logo on Fitbit and a progress bar and Downloading progression on Fitbit app on phone
Then follow through steps on Fitbit and phone to re-setup Versa
this has worked for me so hope it works for you.
It is like the Fitbit got lost so you have to reconnect it all over again.
Good Luck.
Best Answer10-29-2021 06:55
10-29-2021 06:55
Hey There,
Nothing seems to be working. Is there any chance to factory reset it using a PC or the cable?
