04-26-2019
21:37
12:12
AlessFitbit
04-26-2019
21:37
12:12
AlessFitbit
I work night shift and would love to be able to manually tell my versa when I am getting ready to sleep during the day so that I can get feedback on my sleeping habits.
04-27-2019 13:18 - edited 04-27-2019 13:25
Hello @SunsetRunner and welcome to the Help forums. I am under the impression that sleep is tracked automatically -- and that the start and stop times don't matter. The important things to know about sleep tracking are
What happens -- what kind of data do you get from your sleep? What does your app show?
Edit -- I did a little search on the Feature Suggestion forum. This thread lists day sleeping as an Existing Feature -- see the comment by @LizFitbit .
Laurie | Maryland
04-27-2019 21:52
04-27-2019 21:52
Hello @SunsetRunner, it's good to see you around in the forums for the fist time.
As mentioned earlier by @LZeeW, sleep is now detected automatically by all wrist-based Fitbit devices, you just need to wear your tracker or watch to bed. The autodetection is based on your movement, when you haven’t moved for about an hour, your device assumes that you’re asleep.
Additional data, such as the length of time your movements are indicative of sleep behavior (such as rolling over) help confirm that you’re asleep. Morning movement tells your tracker that you’re awake.
Let us know if you have further questions.
04:40
16:09
DavideFitbit
04-28-2019
04:40
16:09
DavideFitbit
My sleep is never shown before midnight and nearly always is reported to be less than 4 hours. My wife is witness to the fact that I go to sleep promptly after turning the light off at about 10:30, but the Versa cannot see it. What's the problem and what's the solution?
Moderator edit: format
Best Answer05-02-2019 16:17
05-02-2019 16:17
Hello @Shaferrj, thank you for all the information, and welcome to the forums.
Since the sleep feature works based on auto detection, if you haven’t moved for about an hour, the Versa should indeed detect that you're sleeping. If this is happening constantly, please try to restart your device following these steps and confirm if you continue to experience the same behavior.
I hope this helps, please keep me posted.
Best Answer05-03-2019 11:15
05-03-2019 11:15
Best Answer05-07-2019 18:30
05-07-2019 18:30
Hello @Shaferrj, thank you for your reply and for your feedback about the product. I'm sorry to see that you continue to have trouble with this.
It's good to know that you already got in touch with the Customer Support team; let them know about the steps you already tried so it is easier for them to let you know how to proceed.
Also, let us know how the device is performing on the following days. You can contact Support directly as you did previously, or you can also let me know here through the Community so I can send them your information and you'll be contacted via e-mail.
Keep us posted.
Best Answer05-08-2019 12:21
05-08-2019 12:21
Best Answer05-09-2019 15:57
05-09-2019 15:57
Thank you for sharing this information @Shaferrj, and for letting us know about your experience with the Customer Support team. Keep them posted about the results in the next few days so they can provide you with the next steps. Thank you also for all your feedback.
Keep me posted on the outcome.
