09-17-2019 13:22
09-17-2019 13:22
On fitbit versa 2 I have downloaded a clock face through the APPS . However, there's a digital "original default " clock keeps displaying! Arggg. If I press the button I'm able to see the face I downloaded for a few seconds-then it goes back to that original default
09-17-2019 13:52
09-17-2019 13:52
I think you're referring to the "Always-on" clock face. Unfortunately, you're preferred clock face (the one you downloaded and can see when you press the button) can't be "always-on", instead, there is a default always-on clock face that has very few customization options.
09-18-2019 07:02
09-18-2019 07:02
oh... gosh... that's disappointing. I'm not a fan of the default clock face at all. I'd love to see the clock face I downloaded each time I look at my watch. There's got to be a way to delete the default face???
Best Answer09-18-2019 07:58
09-18-2019 07:58
As far as I know, you cannot use any other clock face for the always-on display mode. You can only customize what shows: https://youtu.be/0-iEHodfVrg
You can turn off the always-on display mode so that you don't see the default face, but then you'll see a black screen when your downloaded clock face times out.
Best Answer09-18-2019 10:58
09-18-2019 10:58
09-18-2019 11:24
09-18-2019 11:24
Yes, I think the always-on clock face should be your chosen clock face, but that's not how Fitbit has implemented it (and they don't make this clear before you purchase either).
Best Answer03-12-2020 10:44
03-12-2020 10:44
Exactly the whole reason I purchased is to change the look of the watch and affect what other people see not what I see while I'm using it
