10-25-2019 23:11
10-25-2019 23:11
Hello there. I got my Fitbit Versa Lite yesterday for my birthday and I've been having some difficulties with it thus far. My main issue at this point in time is that I can't install apps like Spotify onto my Fitbit. It says either my watch or my app is out of date, but both refuse to update any more. I haven't compared the version numbers, but I'm not sure they'll tell me much as this point. Help would be appreciated. I'm also having difficulty with notifications showing up, but one thing at a time. Thank you in advance.
Best Answer10-26-2019 07:20
10-26-2019 07:20
Is your phone on the list of Approved Devices and does it have the updated Operating System mentioned in the article I referred you to?
Best Answer10-26-2019 08:31
10-26-2019 08:31
Yes, my phone and system are on the list.
Best Answer10-26-2019 13:01
10-26-2019 13:01
Try a Restart and do it several times if necessary.
Best Answer10-26-2019 14:02
10-26-2019 14:02
From my knowledge, I've restarted it 3 or 4 times to no avail. In all honesty, I think the versa lite itself needs to be updated, but it says it's up to date on the app. I compared some version numbers and mine seemed to off a few patches.
Best Answer10-26-2019 15:29
10-26-2019 15:29
I'm having the exact same problem! I just got mine, too. I set it up Thursday night, and it says the version of the app or watch need to be updated to install Spotify. I can't figure out the issue.
Best Answer10-26-2019 16:10
10-26-2019 16:10
Both of you need to do a Factory Reset which forces the latest update. Swipe left to Settings, then About, and then Factory Reset.
