04-29-2019 03:19
04-29-2019 03:19
Hi,
Is it possible to disable Quick Replies, but still get notifications?
As the notification turns the screen on, my fitbit made a quick reply by accident, and this is annoying...
Maria
04-29-2019 08:32
04-29-2019 08:32
You cannot turn this feature off and still have notifications enabled. You can customize them though so that they are all blank.
Best Answer04-29-2019 08:44
04-29-2019 08:44
Thank you for you answer, @SunsetRunner!
But a blank text would mean that i would answer it anyway, but sending a blank message, right?
Best Answer05-02-2019 06:51
05-02-2019 06:51
That is correct
