01-06-2023
04:59
17:50
LucioFitbit
01-06-2023
04:59
17:50
LucioFitbit
The feature to disable 2fa doesn’t work at all it says an unknown error occurred and I can’t login
01-08-2023
17:51
09:11
01-08-2023
17:51
09:11
Hi there @Runningaway0092. Welcome to Community Forums.
Thank you for reaching out to the Community. I'd recommend you check these articles, What are Active Zone Minutes or Active Minutes on my Fitbit device? and How do I track heart rate with my Fitbit device?.
Best AnswerThanks for the help LucioFitbit, but I cannot login on any device, in all cases it says "Enter SMS Code" and I do not have the phone number it is texting anymore. I click on "Disable 2FA" then "Use Email Method" and then it says "An Unknown Error Occurred" and in the end I cannot login, I have called Fitbit support and they say they cannot help me with this also.
