07-30-2019
23:49
04:47
JuanJoFitbit
07-30-2019
23:49
04:47
JuanJoFitbit
I previously had a Charge 2 and before that an Alta, and other Fitbit trackers. I'm on my 5th or 6th device. My previous trackers calculated 2300 - 2500 steps as 1 mile. But with Versa I have to take almost 4,000 steps to get to a mile. Why the difference? Why so wrong?
08-03-2019 04:46
08-03-2019 04:46
@CarolM76 I'm sorry for the late response. However, let me welcome you to our Fitbit Fitbit Community and thank you for being part of our Fitbit family for all this time.
Regarding the distance accuracy that your Versa is tracking, please restart it as described in this help article. This will refresh your watch internally. After this, please check out this help page, under the subject "Does the wrist I wear my device on affect accuracy?" and follow the tips so you can monitor your watch to see if the distance accuracy is tracked better.
You can also visit this help article, which explains how to wear your watch for better results.
Keep me posted on the outcome! ![]()
Best Answer08-03-2019 10:42
08-03-2019 10:42
Check settings: Stride length.
Dashboard: Go to Settings - Personal Info - Stride Length: Set to Automatically or if you know yours 'set your own'.
If you’re doing this calculation outside, bring a piece of chalk and a measuring tape. If you’re doing this inside, have a tape measure and some masking tape.
If you want to calculate your walking stride length, divide the number of steps you took by 2 and divide that number into the measured distance. If it took you 16 steps to cover 20 feet, divide the number of steps (16) by 2 to get the number of strides. Then take the answer (8) and divide it into the distance. Distance in feet/number of strides = stride length. In this case, you took 8 strides in 20 feet, so your stride length would be 2.5 feet (30 inches).
If you want a more accurate measurement, use a longer distance:
For even more accuracy, do the longer distance three or four times, and then average the results.
On average it takes about 2,000 steps to walk a mile.
There are 5,280 feet in a mile. To determine the number of steps it will take you to walk a mile, divide 5,280 by your step length. To determine the number of strides it will take you to walk a mile, divide 5,280 by your stride length.
Hope this helps yourself & many others!
