10-07-2018 07:54
10-07-2018 07:54
There are supposed to be three stats shown on the Versa face during the Run tracker as far as I can see. When I go into Customize Stats there are options for the top, middle and bottom. I would like to show distance (in kilometers) on the top, heart rate in middle, and time lapsed on the bottom. When I set it up, I only get heart rate in the middle, and time on the bottom, and there is no top number. When I'm running and I get to 1 kilometer my watch will buzz and tell me it's 1 kilometer and then 2, 3, etc. when they occur but I would like to see my progress as I go. Why am I not seeing anything for the top stat?
10-08-2018 12:16
10-08-2018 12:16
@versatilemac Welcome! It's great to see you around. I will gladly assist you with this. You don't see the top stat if your device is looking for GPS signal. Once it gets one from your phone then you will see it. You can also disable it on the exercise settings area (tap the gear icon at the top left corner). So you see the stat from the beginning.
Let me know how it goes!
10-08-2018 12:16
10-08-2018 12:16
10-08-2018 12:42
10-08-2018 12:42
THANK YOU. That was the problem. Working fine now.
11-06-2018 08:03
11-06-2018 08:03
@versatilemac sorry for the late reply. Happy to hear that this worked for you and I wanted to thank you for confirming that this helped as it may also help other members in the same situation.
I'll be around!
