03-06-2021 10:32
03-06-2021 10:32
what are exercise short cuts and how do you select/set them: walk & yoga
03-06-2021 10:45
03-06-2021 10:45
From clock face on Versa 2, scroll right to 'Exercise'; tap that, then scroll through exercise choices. These are called the 'Exercise Shortcuts'. You can choose which choices you see and it what order by looking here:
How do I track my workouts with my Fitbit device?
After you select your choice of activity, then start and end it from your wrist.
03-06-2021 12:37
03-06-2021 12:37
Best Answer03-06-2021 12:43
03-06-2021 12:43
The 2nd half of the answer is the same on how to select and order them.
To get to them, I'm just trying to remember the Charge 2. I think you press the side button repeatedly until you come to 'Exercise';
then tap the screen to scroll through the different Exercise Shortcuts. And can set the exercise shortcuts as described in the link above.
