Why isn’t swimming under Exercise on the Versa Lite. You can add it on the Insprire but the Versa
Best AnswerIt is there but if you have 7 exercises selected, you have to drop one in order to add Swim. Go to Fitbit.com and click on the gear icon at the upper right and then Versa Lite. Scroll down to Exercise Shortcuts and set it correctly by clicking Edit and put a check mark by Swim. Then scroll on down and click on Submit and then sync your tracker.
Best AnswerOn Versa Lite swimming is tracked only by autodetection (SmartTrack). You can't manually start swim exercise.
