Face clock in sunlight
If I’m outside in the sunlight, will I be able to see the time on my versa two? I have a Fitbit inspire now and I can only see the time clock face is it I cover it or it is dark. When I’m outside in the sunlight, I can’t see what time it is. Well, I had the same problem with the versa two?
1 REPLY 1
Hi @SS5513 - if you set the Brightness to max you can still have a problem in direct sunlight.
Often it depends on polarisation of dark glasses or photochromique glasses if you wear them.
It also depends on the size and colour of the digits on the clock face.
There are many different clock faces in the Gallery and you should be able to find one that works for you.
