11-28-2022 06:54
11-28-2022 06:54
Hi there I need your help my Versa 2 is "Unlock with Phone" i cannot open it and it already unpair to my Cellphone
11-28-2022 07:41
11-28-2022 07:41
Hi @akosijose - you may be able to simple repair it then unlock it with the phone.
Logout of the Fitbit App
Login again and head to the phone home screen without closing the Fitbit App.
A sync popup should appear, click on it and wait for the pair and link prompts and then sync.
This link might help How do I use the device lock on my Fitbit device?
Best Answer11-28-2022 12:44
11-28-2022 12:44
@Guy_ i tried that but its still unpair is there a way to factory reset the versa 2 without using the setting>about>factory reset?
12:49
11:38
11-28-2022
12:49
11:38
@akosijose - yes there is but a factory reset can fail, and only to be used as a last option.
You can chat via the Fitbit App, click profile photo Help & support, Contact Customer. They will guide you through it.
