11-04-2019 08:42
11-04-2019 08:42
Is it possible to do a factory rwres on a versa 2 when the swipe on touch screen has stopped working?
On versa 1 you could hold in all 3 buttons or something similar..but here you only have one button..?
11-04-2019 10:42
11-04-2019 10:42
Use the procedure on page 59 of your User Manual that they now call Erase and then reinstall.
Best Answer11-04-2019 10:56
11-04-2019 10:56
11-04-2019 11:00
11-04-2019 11:00
My bad!!! Contact Customer Support.
Best Answer08-02-2020 09:26
08-02-2020 09:26
I was wondering if you were able to get the issue sorted out?
I'm having the same issue and want to do a hard reset, but can't on a non-functioning touch screen.
Any assistance would be appreciated.
Thanks in advance.
Best Answer08-02-2020 09:32
08-02-2020 09:32
Best Answer12-28-2020 14:32
12-28-2020 14:32
I fixed it by just holding the one button until it reset.
12-29-2021 04:18
12-29-2021 04:18
Hi my versa 2 is stuck with the logo screen flashing on and off any help would be appreciated. 🙂
