It would be great if I could toggle/switch screens and run 2 apps on the versa 2 when I set the exercise app and go for a walk or run. Then I could set the exercise tracking app and switch to Spotify to change the song when needed. It's annoying to have to use my phone bc once the exercise tracking is running you cannot navigate away from this screen on the versa 2.
08-20-2022
23:17
09:55
08-20-2022
23:17
09:55
Hi @SunsetRunner - this is possible, just use the built in Music controls [double press the button] instead. It is a system app and can run when other things are running. Not only that it can change the volume level and you won't need Spotify premium.
Note: the watch can either use a clock or an app at any one time. The exception is system functions such as Music Controls, Voice Assistant, Quick Settings which can run at the same time.
