05-03-2022 10:00
05-03-2022 10:00
I recently installed the latest firmware update on my versa 2 and it stopped working (watch was 14 months old). Contacted customer service and since the device was no longer covered under warranty I was given the option of buying a new watch at a discounted price. I bought a new versa 2 and am getting notifications that an update is available. I am hesitant on installing the update because of what happened to my other device. My question is has anyone else on this forum had a similar issue and purchased another watch, and if so did you install update successfully?
05-03-2022 10:19 - edited 05-03-2022 11:06
@74328 I've never had the exact same issue of buying a replacement due to update failure, but I've never had a Firmware update problem across 4 different models in 6 years.. And if it's brand new, it's returnable right? You have nothing to lose by updating. You don't even have options like SP02 until the update that comes a few days after using a new Versa2.
05-04-2022 09:09
05-04-2022 09:09
Hi, yep the update ending 19 bricked 2 versa 2s I had, screen went black yet still worked.
Try deleting it on phone and put it in as new device, that got one work ing for a bit,
My one had been no trouble at all till I got the firm ware update and next morning screen black, yet phone still connecting. Got to be a bug in the update. Hth
05-04-2022 10:38
05-04-2022 10:38
I got an replacement and it doesn’t work properly. It does the same as my old one did after the update
05-12-2022 18:08 - edited 05-12-2022 18:40
I wouldnt trust an update if you are out of warranty. Wife updated her and now her battery doesn't even last a day.
05-12-2022 18:16
05-12-2022 18:16
My Fitbit was still in warranty. They sent me a replacement but it wouldn’t connect without doing an update on it and it had the same problem my other had. Couldn’t read heart rate so nothing was reading correctly. When I complained again I was told there was nothing they could do for me. They said maybe it would fix itself or maybe the next update would fix it.
05-14-2022 07:22
05-14-2022 07:22
If it's still under warranty, go for it!
one cruise ship at a time!
