01-02-2019 11:00
01-02-2019 11:00
I have a Fitbit Versa, it is updated to the latest OS - 33.1.30. I have it synched to my iPhone 6s running iOS 12.1.2. Since I got my versa, I have never ever been got notifications on the watch when I received a Text message or an iMessage. I was having issues for a bit with WhatsApp but, it and all other app notifications that I want turned on (Ring, my alarm system etc) I received. Also, incoming call notifications I receive no problem.
On the app I have turned on notifications for "Text Messages" - same as for "Calls". When I had issues with WhatsApp, I would turn off notifications for the app and then sync and then come back in and turn it back on and sync again.
Like I said, I have never received a Text/iMessage notification since I got the Versa. It's really annoying and am considering sending it back at this point as it's one of the more important notifications I want to be able to receive.
10-09-2019 13:04
10-09-2019 13:04
Go on iPhone settings, notification centre and pick either “always” or “when unlocked” for message previews. I did that and it now works.
10-16-2019 22:47
10-16-2019 22:47
Same issue, I wasn't able to sync my texting until I did this:
Iphone Settings - Notifications - Messages - under Alerts I had to click on Notification Center and Show Previews as "Always (default)".
12-12-2019 16:36
12-12-2019 16:36
This works!! thank you!
Best Answer12-25-2019 18:36
12-25-2019 18:36
This worked for me! Thank you!
Best Answer12-30-2019 20:55
12-30-2019 20:55
I figured out my problem on my end. If u have “show preview off” in messages it blocks the phone notification
i turned it to when unlocked or always and it works just fine.
Bummer because I wish it would show a message but still keep it private
Best Answer03-11-2020 10:16
03-11-2020 10:16
THANK YOU SOOO MUCH!
This has been consuming my time and patience for soooo long and this actually worked!
i honestly can’t thank you enough, I owe you a beverage of your choice!
04-23-2020 10:40
04-23-2020 10:40
I have tried contacting the Fitbit people repeatedly with this issue. I was even on a long text thread with customer service for months. I never had my issue resolved. They kept saying they knew about the issue but that they were working on it. Clearly, the issue still hasn't been fixed as I still have the same problem, even after I was hoping this new update would fix it!
Best Answer06-27-2020 10:33
06-27-2020 10:33
I have a Versa 2 and iPhone 11 Pro with latest iOS 13.4.1
I was getting calendar and phone call notifications but not Text Messages/iMessages.
The issue for me is that I have the text message previews turned off on my lock screen. It's a security feature from Apple, if someone picks up my phone they cannot view my messages unless my phone is unlocked so that's why messages don't come through on a 3rd party device.
To resolve:
Go to Settings -> Notifications -> scroll down to "Messages"
Tap on "Show Previews" then tap on "Always (Default)"
That's it. You shouldn't have to restart anything. Once I changed this I got text messages and iMessage popping in.
Best Answer09-10-2020 00:44
09-10-2020 00:44
Thanks. This method worked!
Best Answer10-20-2020 08:46
10-20-2020 08:46
Thats worked, best answer 🙂
