Hi all.
After the last update, I am having trouble with Fitbit Pay. There is the ability to access the Fitbit Pay Visa cards when you swipe down from the top of the screen on the Versa, in the latest update. The card works the first time when this is done but after that, it doesn't work until you do a reboot, and then it only works for the first time again. I hope that there is a fix for this in the next update.
Thank you.
When you say that it doesn't work @Patch2000. What type of error do you receive?
Have you tried disabling the card and setting it up again?
Best AnswerHi Rich.
I don't get an error message, the watch just doesn't make contact with the card reader after the first time. I'll try uninstalling the card & installing it again as you suggest. Thanks for your reply.
