Hi All,
My Versa 2 is extremely uncomfortable. My wrist is 6.5in, so I have the original band, but I’m not sure if I should wear it higher on my wrist. Should I get a bigger band? Has anyone else had this issue?
Help!
Thanks,
Jeanette
Hi @Nina1985 the small size goes to 7.1 inches and the large goes to 8.7 inches. Maybe a different style band would be more comfortable? Some people buy bands from Amazon and even handmade ones from Etsy to have the extra comfort, so you might want to check around.
