10-12-2023
10:55
20:18
EstuardoFitbit
10-12-2023
10:55
20:18
EstuardoFitbit
My Versa 2 used to hold a charge for at least a week. Since the app updated I have encountered endless problems. My fitbit was charged fully yesterday and within 24 hours the battery has completely died. My fitbit is over three years old and have had zero issues with the battery in the past. Beyond disappointed.
Moderator Edit: Clarified Subject
10-12-2023 20:17 - edited 10-12-2023 20:19
Hi there @1491sar, welcome to the Fitbit Community.
I appreciate you informing us to the Versa 2 battery problem. I recognize your frustration and can understand why you are feeling this way.
I would like to recommend taking the steps described here for a device that is draining quickly. Please be aware that there are a number of potential causes for this inconvenience. Your Fitbit device's battery should start functioning as intended if you follow the instructions provided there.
Best Answer10-13-2023 05:45
10-13-2023 05:45
I have the same issue. It used to last a week, but now I have to recharge it every two days. Mine is also 3-4 years old.
10-13-2023 17:20
10-13-2023 17:20
Hi there @KevinSW, thanks for joining this thread.
Taking into account the potential effects of charging time and duration on all types of batteries. It is typical for any device's battery to not last as long as it does on day one. I sincerely hope you can understand, but I'd also like to give you the chance to get in touch with our support team to learn more about your warranty alternatives.
Best Answer10-13-2023 17:57
10-13-2023 17:57
Mine is less than a year old and the rapid draining started just a week ago. I have checked all settings and Bluetooth is off. Has never been wet. Battery drains flat in about 6 hours whether I move or not. Have cleared the cache and gone through the checklist you provided earlier in this thread. Restarted watch. Nothing helps.
10-14-2023 00:36
10-14-2023 00:36
That might be nice. Yesterday it started bootlooping at around 30%, and eventually it turned off and now it doesn't do anything anymore no matter how long I press the on button. When I checked the support pages it told me they don't exist.
Best Answer10-14-2023 03:14
10-14-2023 03:14
10-15-2023 07:02
10-15-2023 07:02
I've done the check list, I've cleared the cache, done everything you've suggested to others in this thread and I'm lucky if the battery lasts 3 days. Is it possible that fitbit needs to come out with a firmware update to address this issue?
10-15-2023 07:08
10-15-2023 07:08
It's sad. They used to have the option to choose how often to sync and stuff. Battery life really went down when they removed said option 😔
Best Answer10-26-2023 22:08
10-26-2023 22:08
While batteries do drain overtime, there is no natural phenomenon that causes a large mass of people who have the same product to all experience massive battery drain at once. Please find and solve this issue for us.
