10-10-2023
00:09
14:43
10-10-2023
00:09
14:43
My Versa 2 has started needing changing everyday. I used to charge it possibly once a week. It is flat with in 24 hours. Why?
Hello there, @Backdoor. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the issue with your Versa 2.
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
