10-30-2022
22:28
06:11
LucioFitbit
10-30-2022
22:28
06:11
LucioFitbit
I have had my versa2 for just over 2 years it has just rolled over 2 months out of warranty and the screen is has like an electronic interference on the screen, am I able to get it sorted or have I just lost the watch altogether?
10-31-2022
06:02
06:43
10-31-2022
06:02
06:43
Hi there @Kazzah66, it's good to have you back.
I appreciate you share your experience. I'd recommend you follow these steps to restart your device.
Also you can try to change your clock face, if this fixes the issue, you can change it back to the original clock face. If you are using a third-party clock face, please switch to a Fitbit clock face and try the troubleshooting again.
If the issue persists please let me know.
Hope this helps.
Best AnswerThank you for your reply LucioFitbit.
I have tried numerous times resetting and it hasn’t worked, the icons don’t stay visible long enough to change faces. Sometimes you can see the clock face and icons behind the fuzzies going on screen. I am also no longer receiving notifications.
I can’t believe the watch is only 2 years old and it seems to be dying? I love all the aspects of this watch so disappointing that it hasn’t lasted.
Cheers Kaz
