10-05-2023
04:31
07:33
EstuardoFitbit
10-05-2023
04:31
07:33
EstuardoFitbit
Does any one is experiencing the same as me ? My versa 2 doesn’t sync its been 2 weeks. And my data is gone. FItBit doest give me a support .
Moderator Edit: Clarified Subject
10-05-2023 10:32
10-05-2023 10:32
Yes mine is the same.....can't figure out why 🤔
Best Answer10-05-2023 10:56
10-05-2023 10:56
Mine is doing the same thing
Best Answer10-05-2023 11:09
10-05-2023 11:09
Welcome to the forums @Ella800 @Llfiddler @Lindyloo99
Thank you for sharing the inquiry regarding this inconvenience. I'm sorry to know about it.
Could you please confirm if you already tried all the steps listed here to resolve syncing problems? Also, please make sure to check if the mobile device you're using is listed here as a compatible device to sync with the Fitbit app.
Best Answer10-05-2023 11:23
10-05-2023 11:23
