01-30-2024
12:39
10:43
RodrigoMFitbit
01-30-2024
12:39
10:43
RodrigoMFitbit
My versa 3 has stopped working tonight I only have it 2 years the Fitbit logo is flashing on and off
Hi @Daisy1962 this is copied from a post where a Fitbit Moderator shared this to help someone with a similar issue on their Versa 3. See if it helps you.
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
@Odyssey13 Thanks for your help. Much appreciated!
@Daisy1962 Welcome to the forums. Thanks for reaching out about your Versa 3 not working properly.
I was informed that you contacted Fitbit support already. I recommend you stay in touch with them. They will provide you with a suitable resolution. I appreciate your patience. Thanks!
