Hello,
I made a new account and attempted to add my Fitbit Versa (which was working perfectly fine) and now it will not add. I follow the instructions to add a new device, it gives me the screen with the pin, I put the pin in on my Samsung Galaxy S9 and then it says "connecting..." for all of 5 seconds before it goes back to the menu and my Fitbit Versa stays at the Fitbit logo screen, not connected. I have tried resetting my Fitbit Versa and phone multiple times as well as turning Bluetooth on and off and uninstalling/reinstalling the Fitbit App. Nothing works. Help!!
@SarahPeaches Welcome! It's great to see you around! Sorry to hear about your Versa not setting up again. Try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try setting them up. Also, since you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Let me know how it goes!
