06-25-2018 14:20 - edited 06-25-2018 14:21
Seem to be having an issue with my Fitbit Versa that is only one month old!!!
Woke up on Sunday morning and my watch showed me a time of 09:52 I decided to shut my eyes for another minute or two before I got up. I got up about 5 minutes later (looked at another clock) to find my Fitbit screen wasn't working properly. As you can see from the first photo after holding down the left and lower right button it does reset as the Fitbit logo is visible.
I'm just wondering whether anyone else has had this problem? What anyone may think has caused it?? And advice on whether to contact Fitbit or the shop I bought it from?
Thank you in advance
03-22-2019 20:48
03-22-2019 20:48
Mine just started doing this, and I’ve had it since october 2018 😭😭😭
03-23-2019 11:57
03-23-2019 11:57
Contact them. They will walk you through a bunch of troubleshooting ideas then check your warranty! You could get a new one. This will be my 3rd one in less than a year (April 27 will be a year since I ordered).
07-01-2019 22:23
07-01-2019 22:23
How long did you have your versa for fitbit to replace it? Ive had mine for 13 months and the screen just messed up today. I havent been able to try what everyone suggested but i will be trying first thing in the morning.
08-06-2019 19:12 - edited 08-06-2019 19:17
Hi @justjessee
Did you get your versa problem solved? I’ve got mine for a little bit over 3 months and the same thing happened today.
It’s still working, as I can update all my data on the app, but the display is completely useless.
08-08-2019 06:23
08-08-2019 06:23
I chatted with support both times my screen went bad. I'm on my 3rd watch and so far so good. I've had this one for a few months and am only using the Bitmoji watch face instead of 3rd party watch faces and am NOT swimming with it. Hoping it lasts longer than 3 to 6 months this time! Time will tell! 😛
08-12-2019 15:21
08-12-2019 15:21
02-03-2020 09:53
02-03-2020 09:53
Me too!
Bought mine in November 2018 and I woke up to this issue this morning 😭
Limited warranty for us looks to be only a year - too bad we don’t live in Europe, then it’s two years! 🙄
02-15-2020 05:44
02-15-2020 05:44
I am also facing same issue ,i also puchased one year back
02-18-2020 09:07
02-18-2020 09:07
@Vijay489 Welcome to the Fitbit Community! I hope you're doing well! Sorry for the delay in my reply.
Let me help you with your Versa screen not working. You don't mention any troubleshoots so I suggest you restart your device by following these instructions.
Keep me posted.
04-27-2020 04:21
04-27-2020 04:21
I've had my Fitbit since September 2019, this screen glitch happened I contacted Fitbit who have refused to honour their warranty. This is the last Fitbit I ever buy! And I've had three,They all of which haven't lasted two years. These are a disposable watch and, in my experience, don't last any longer than about 2 years anyway. I've found a much cheaper replacement £35 that does the job with excellent reviews and Fitbit will never receive another penny from my pocket. Utter crap products over priced and not fit for purpose.
05-09-2020 15:14
05-09-2020 15:14
I am having same issue, exactly as your picture... I send email to fitbit and am still waiting if is going to be replaced
05-09-2020 15:16
05-09-2020 15:16
I am in the same situation, I might have to go back to my gear 2
05-26-2020
11:54
06:18
05-26-2020
11:54
06:18
@Kokofeliu17 Thanks for stopping by! Sorry for the delay in my reply.
Let me help you with your Versa screen not working. Since you are already in contact with our Support team please keep working with them to find a solution. Hopefully they will be able to help you.
Let me know how it goes.
06-27-2020 09:22
06-27-2020 09:22
Fit BIt needs to fix this issue. The previous one was sent back to Factory due to a faulty screen. Replaced Fitbit versa Screen is blank again. it is vibrating counting steps as if all is normal. But screen is showing blank. tried changing clock face maybe that was an issue (thought so). still no luck.
Why can't Fitbit fix this issue for once? or if they can't fix, stop selling the devices. almost every model has this issue.
07-05-2020 05:09
07-05-2020 05:09
I had this with two versa lites so i bought the versa 2 and one month after buying it mine is doing the same. Is this a common issue on quality control?
07-05-2020 05:11
07-05-2020 05:11
That often happens if you allow it to go fully flat. In you app turn off automatic time and set it then it’s fine
10-17-2020 16:01
10-17-2020 16:01
I’ve had the same issue with my versa, bought in 2018, had it replaced. My replacement just went bad last night. I called they said nothing they can do. It happy to see this seems to be a common issue and Fitbit didn’t seem to want to help at all. Not happy.
10-17-2020 16:16
10-17-2020 16:16
This happened to me but I've had it over a year. I woke up one day to a black screen even while it's charging. However it still vibrates when messages or any notifications come through.
10-17-2020 22:38
10-17-2020 22:38
04-19-2021 23:54
04-19-2021 23:54
This has started happening with my fitbit versa 2 that i only hss for christmas
The 1st time i did an update and it corected it
The 2nd there is no update!
Sofar ive tried turning it off and on twice not stopped it
And turned my bluetooth off on my phone then bk on
Watch is at 25% so put on charge with it off to see what it does
Both times its done this after wearing it to bed?
