06-14-2019 07:05
06-14-2019 07:05
This morning my versa said 0% battery, I thought this was odd as I hadn’t had the usual email saying that battery was low. I immediately put it on charge, the screen went blank and I haven’t been able to turn it on since. I left it on charge for 2.5hrs this morning, when it wouldn’t turn on I tried holding down the left and bottom right buttons a number of times (as described on forums) with no avail. I plugged it into computer to charge for another 3hrs, nothing. Tried the 2 buttons again, nothing. Tried resetting using all 3 buttons, nothing. This was only bought in October last year and has been treated well, very frustrating that such an expensive bit of kit is failing!
06-15-2019 07:02
06-15-2019 07:02
@Ellie78 welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since the display won't turn on. By the way, thank you for troubleshooting this issue before contacting our forums.
I'd like you to try cleaning the contacts of your Versa and charging cable with a cotton swab in order to remove any dust that the contacts accumulate. After this, try charging your Versa through another USB port of your computer and see if it comes back to life.
Keep me posted on the outcome! ![]()
Best Answer06-15-2019 08:12
06-15-2019 08:12
I also bought a versa in November 2018 and it just stopped working last week. I have tried cleaning it with a toothbrush and left it charging for a week and nothing happened. when i pressed on the buttons together on the side of the versa only green and blue light is shown for a few second and then the lights fade away.
06-15-2019 15:43
06-15-2019 15:43
Best Answer06-15-2019 15:43
06-15-2019 15:43
Hi, thanks for your reply, I have now tried cleaning and charging from another computer port, unfortunately it has not made any difference. Still not working.
06-15-2019 16:50
06-15-2019 16:50
Any solutions to this problem?
Best Answer06-23-2019 23:55
06-23-2019 23:55
Any other ideas?!
Best Answer06-24-2019 07:37
06-24-2019 07:37
Yep...the same happened to me.I hope you are going to get better luck than me with their customer service.I belive that it is a well known defect with the device but totally ignored by Fitbit.
Best Answer06-24-2019 09:32
06-24-2019 09:32
It has been over a week since my Fitbit failed, I have tried everything you have suggested and still it doesn’t work. Feeling very frustrated with the slow response. This was not cheap, it has been treated properly and it should be working. 😡
Best Answer06-24-2019 10:26
06-24-2019 10:26
I called customer support and they were actually very helpful. Did some troubleshooting over the phone....nothing worked. They are sending a replacement..should be here today.
Best Answer06-24-2019 11:30
06-24-2019 11:30
Lucky you...they did not replace mine...unless I accept the black model..I am happy that you got a better outcome than me.
Best Answer06-24-2019 12:13
06-24-2019 12:13
London Drugs agreed to replace my Fitbit with the same color model...koodos to them...not happy with Fitbit .I will not purchase Fitbit products anymore.
