04-14-2018
11:13
19:47
EdsonFitbit
04-14-2018
11:13
19:47
EdsonFitbit
You long press the left button to bring the digital card on your versa (only the special editions have the fitbit pay). Then when you rotate/move your hand to take it closer to the card reader, the versa picks up the motion and turns screen off
Moderator edit: added label
04-15-2018 05:30
04-15-2018 05:30
Once you press the left button to bring up the card, it should work regardless of the screen being on or off.
Try restarting your Versa by pressing and holding the left button and bottom right button together for 15 secs, this may help to clear out any software glitches.
Best Answer04-14-2018 11:18
04-14-2018 11:18
this work when you have the auto feature on. But obvisouly while the fitbit pay is on, arm movement shouldn't turn off the screen. It is ridiculous the versa is shipped with this "bug"
Best Answer04-14-2018 20:06 - edited 04-14-2018 20:07
It works fine for me. I've never had this happen.
I just tested it. It does turn the screen off, but it still works.
Best Answer04-14-2018 20:30
04-14-2018 20:30
The NFC technology has nothing to do with the device's display.
You could have an Ionic (or Versa) with a broken display that would never turn on and if you're able to navigate the device until you find your card, the chip inside the Fitbit will take care of the transaction.
04-15-2018 02:22
04-15-2018 02:22
Thanks for your input. I'd have to try again. But every time I tried, while the screen turned off, the NFC reader did not register anything.
Best Answer04-15-2018 05:30
04-15-2018 05:30
Best Answer04-15-2018 05:32
04-15-2018 05:32
Did restart my versa and the next time it worked. Cheers!
@N8teGee wrote:Once you press the left button to bring up the card, it should work regardless of the screen being on or off.
Best Answer04-15-2018 05:33
04-15-2018 05:33
Excellent, glad it's working for you now
