01-29-2020 17:11
01-29-2020 17:11
I love this watch. Only had it 3 months so was pretty gutted the other day when I looked down to check the time and it was off.
I tried turning it on, and got nothing.
I had only charged it the day before but I put it on charge anyway and got nothing.
So, I tried the restart a few times and also got nothing.
My partner and I have one each so I tried the other charge, which I know works, fine but still nothing.
Just black.
It has never been knocked or in water (because I don't trust water proof).
Anyone else had this? I'm out of Ideas.
Expensive item to last only 3 months.
01-29-2020 17:44
01-29-2020 17:44
My Versa did the same around 3:30 PM today. About an hour ago I tried to sync it with my app and it would sync halfway then stop. So I deleted the Versa from my app and tried to reinstall it. It would get hung up after I typed in the four digits and give me a 503 error, which I’m not sure what that means, but I’m going to research and hopefully figure it out.
01-29-2020 18:12
01-29-2020 18:12
This just happened to me tonight! I know it had plenty of charge, when I logged my afternoon water bottle it was at 63%. Sitting on the couch around 8pm I get a low battery notice and now it's completely unresponsive even on the charger. This is my second warranty replacement so 3rd Versa in under a year. Beginning to wonder if it's even worth asking for another, they don't seem to last.
01-29-2020 19:02
01-29-2020 19:02
my versa quit on me last night, flat out dead. The battery was running down so I figured it had died. When I set up the charger, it would not even illuminate to show it was charging. I tried several different outlets and even another charger. The watch is completely dead. so bummed. I've tried restarting it, nothing.
01-30-2020 05:41 - last edited on 01-30-2020 16:55 by LiliyaFitbit
I did get my Fitbit working again and connected to my app last night. I shut down my Fitbit Versa, and restarted it six times. Then I opened my Fitbit app and was able to connect the two, and so far my Fitbit is working. Maybe this will help you?
01-30-2020 13:16
01-30-2020 13:16
01-30-2020 13:38
01-30-2020 13:38
It seems there are a lot of people having these issues. It happened to mine and restarted on their advice and thankfully it started charging. However, my battery was lasting 4 days and all of a sudden it's 2. They keep trying to tell me it's about right for my usage which is BS as it was working fine until they told me to do that! I'm so annoyed at the moment! Hope you find a fix for yours 😬
01-30-2020 13:41
01-30-2020 13:41
My fitbit versa stop working in November. It died at work got home yo charge it and nothing. Cleaned off the charger and my watch nothing. It's not the charger because my husband uses it for his watch. Only had it 9months! I think they should send me a new one!!!😠
01-30-2020 13:44
01-30-2020 13:44
Have you done a restart on it at all? Although if you do you're likely to have battery issues after! This is what's happened to me!
01-30-2020 14:34
01-30-2020 14:34
My Versa will not charge either. The battery was low yesterday so I thought just needed recharging. How do you restart it?
01-30-2020 14:53
01-30-2020 14:53
Try to push the button on the left for few seconds until you see on the screen Battery 0%
Then plug is quickly to the charger
This strange behavior came with the last Firmware update (perhaps it is a coincidence but this is what I noticed)
Finally my Versa died few days ago, hopefully still under warranty,... the support will send to me a new one... the 3rd in 18 months... too bad, but the Support Guys are nice 🙂
01-30-2020 15:08
01-30-2020 15:08
01-30-2020 15:09
01-30-2020 15:09
Good for you 🙂
01-30-2020 15:43
01-30-2020 15:43
01-30-2020 15:44
01-30-2020 15:44
01-31-2020 19:12
01-31-2020 19:12
that did it for me. thanks!
02-01-2020 01:47
02-01-2020 01:47
My Versa died as well, wont respond to the charger. What is the next step to get it sorted, can someone help please?
02-01-2020 02:39
02-01-2020 02:39
Hey you need to hold down the big button on the right and the bottom button on left until you see the fitbit logo this will restart it hopefully and you should then be able to charge. This happened to me bit the charge went down from lasting 4 days to only 2 so this could happen. Hope it works for you! 😁
02-01-2020 02:40
02-01-2020 02:40
Sorry correction big button on left and button button on right 🤦🏼:female_sign: getting my left and right mixed up!!!
02-01-2020 06:40
02-01-2020 06:40
Don't lose time, context the support by email or Twitter, you'll see if something is possible... They changed mine...
